Yes how does one make the film fluent without stopping every now and then :-( What have we done wrong with this one? Regards. /Janne
Janne this seems to be normal for me. When I play it on the main Vimeo screen it is smooth. If I enlarge it then it gets choppy. I've always thought it was due to processing power of my video card but not all videos have the issue. A guess, load it as a 720p instead of a 1080. Give that a try and see if it makes any difference.
Hi Janne: Have you seen the recommendations for compression on Vimeo?https://vimeo.com/help/compression Apologies if you've already seen them. I'm not sure that's the cause of the stuttering on playback -- that could be anywhere in the chain between your machine and their server. Unfortunately, vimeo.com does not respond to a "ping" so you cannot easily test what kind of connectivity you're getting to their server(s) other than by trying to play a video. I certainly email them if you have a Pro account and complain. By the way, was the video in your posting supposed to be an example of the problem? It played very smoothly for me, but I have fairly high speed access to the Internet (100 megabits/second) and I suspect I'm fairly "close" (in packet routing) to their servers.... Andy.
