Uncontrolled Yaw
Discussion in 'Electronics' started by Anthony Shorten, Apr 13, 2014.
  1. Anthony Shorten
    Anthony Shorten New Member
    May 28, 2013
    24
    Hi All,
    Hopefully some body can shed some light on an issue that I have had over the last year. On three occasions I have lost right yaw for about a period of about 6 seconds which is very unnerving as you can imagine. What happens is after yawing left then right then left I completely loose right yaw, I can give it full right yaw but nothing happens, I originally thought that this might be a motor issue but i recently replaced all motors with the new mk3644/24 and a brand new double Quadro cool board and on a flight on friday experienced the same issue. Could it be a faulty gyro on the flight controller board ? there are no errors in the log and I can see the sticks on the remote issue the yaw command and nothing happens ?? all motors are vertical and straight and my props are new.
    Any thoughts
    Cheers
    Anthony
    10,356
    1,161
    Anthony can you provide more details of the copter -- is this a Cinestar?
    What are the avionics boards that you are using, please? (Other than the double Quadro, which you do mention.)
    Do you have a GPX file from the flight where you had this problem? (EDIT) And can you post the file, please.
    And.
  3. Anthony Shorten
    May 28, 2013
    24
    Hi Andy, It is a Cinestar 8, FC2.2 Navi 2 firmware 2.04 the strange thin is that in the logs before the motor and distro board upgrade the opposite motors draw more power, and the same now that i have replaced motors, props and distro board. Cinestar is balanced perfectly as well.
    Thanks in advance
    10,356
    1,161
    Hi Anthony: Could you post the GPX for the flight where you had the issue please? From what you're describing, given that the Cinestar, the motors, and the props are all balanced, it's hard to account for the problem...
  5. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    839
    67
    Andy Im thinking its a compass issue!
  6. Anthony Shorten
    May 28, 2013
    24
    Hi Andy,
    Here is the log.
    Anthony
  7. Anthony Shorten
    May 28, 2013
    24
    Hi Jason,
    I have had this issue once without the navi board connected, so my thought is that it could only be the FC ?
    Anthony
  8. Andy Johnson-Laird
    10,356
    1,161
    Anthony: There is serious asymmetry in the motor currents. All the even numbered motors are drawing about half the current of the odd numbered propellers, those are the ones spinning clockwise.
    What is not clear whether this is an instrumentation fault -- or the data is really reflecting reality. I would suggest that you use MK_GPXTOOL and have a look at some of the earlier flights you did to see whether this is a trait that is reflected in all the flights.
    I'm not sure what the cause of the problem could be though. Usually one sees one "lazy" motor, but in this case all clockwise ones? Hmmm.
    Can you verify in MK Tool:
    1. Which parameter set you are using.
    2. Which mixer you have set.
    MK Version: FC HW:2.2 SW:2.04a + NC HW:2.0 SW:2.04a
    Flight date: 4/10/2014 4:38:17 PM
    Flight time: 4:38:17 PM - 4:38:45 PM (28 secs, 00:00:28)
    Batt. time : 29 secs, 00:00:29
    Start Lat./Lon. : -26.8260463 / 151.8968046
    Elevation(GPS) : 0 2.15 3.94 m (min/avg/max)
    Altitude(Barom.): -0.75 1.5 3.8 m
    Vertical speed : -1.07 -0.03 0.92 m/s
    Max speed : 19.1 km/h
    Max target dist.: 0 m
    Max distance/LOS: 16.6 m / 16.6 m
    Sats : 8 9 10
    Voltage : min. 14.4, max. 15.5 V
    Current : 0.5 42 71.5 A
    Wattage : 8 636 1029.6 W
    Capacity: 367 mAh
    Motor1: 0.0 9.7 15.0 A Temp: 24 26 28 °C
    Motor2: 0.0 2.2 6.1 A Temp: 24 24 26 °C
    Motor3: 0.0 9.2 13.3 A Temp: 28 30 32 °C
    Motor4: 0.0 2.0 6.0 A Temp: 24 25 26 °C
    Motor5: 0.0 8.3 13.1 A Temp: 25 27 30 °C
    Motor6: 0.0 1.3 5.1 A Temp: 22 21 22 °C
    Motor7: 0.0 6.3 10.0 A Temp: 27 29 31 °C
    Motor8: 0.0 1.9 5.4 A Temp: 22 21 24 °C
    Magnet Field: 104 108 119 % (ok)
    Magnet Inclination: 53 55 61 deg
    No errors found ;)
  9. Anthony Shorten
    May 28, 2013
    24
    Okto 2 mixer set, same issues in earlier logs
  10. Anthony Shorten
    May 28, 2013
    24
    ohhh maybe the wrong mixer set, should i be using the okto mixer setup.......
  11. Jason Smoker
    Oct 23, 2012
    839
    67
  12. Andy Johnson-Laird
    10,356
    1,161
    I think the correct one is the Okto2.
  13. Anthony Shorten
    May 28, 2013
    24
    on the okto 2 every second arm was shorter i switched the mixer settings back to okto maybe this will help.... any other ideas
  14. Andy Johnson-Laird
    10,356
    1,161
  15. Andy Johnson-Laird
    10,356
    1,161
    Anthony: I think you're taking the diagram too literally -- the "arms" are not shorter -- it's not a scale diagram. :)
  16. Anthony Shorten
    May 28, 2013
    24
    Sorry I'm plucking at straws here :)
    Anthony
  17. Anthony Shorten
    May 28, 2013
    24
    Hi Andy,
    What do you think, is this a Compass issue or maybe a faulty gyro on the distro board ? Its really starting to get to me
    Regards
    Anthony
  18. Gary Haynes
    We need a photo of your copter setup please.
  19. Anthony Shorten
    May 28, 2013
    24
    Hi Gary,
    Do you know anything about the Okto2b mixer settings on the new software, Sending a pic through soon.
    Anthony
  20. Anthony Shorten
    May 28, 2013
    24
    Hope this helps fc is out at the moment and 3 axis mount is off
    Anthony
