I can't seem to be able to get an asus memo pat hd7 to connect to the movi. I am able to with a macbook air and another pad i tried. The app install fine. The blue tooth works and pairs with the movi but when i try to connect it via the app it doesn't work. I took the steps of re trying a bunch of times. deleting, re installing, clearing app cache, etc.. even updating to os for the pad. Still "no connection" mind you i'm new to android tablets. please chime in on possible causes Thanks
Chris: I don't believe you're the first person to report this problem, but I've not seen anyone post the solution. The usual problem is forgetting to allow non-Play store apps to install, but it sounds like you're way past that.... Perhaps one of the other forum members has some idea of how to proceed... I've installed it on both a Galaxy Samsun Note 10.1 and a Google Nexus 7 and, in both cases, it worked first time -- this doesn't help you at all, I realize, but it it does confirm that the app does work under Android. Andy.
