U8 T-MOTOR
Discussion in 'Cinestar 8' started by Emdy Jones, May 6, 2014.
  1. Emdy Jones
    Emdy Jones New Member
    Jan 20, 2014
    10
    I bought the U8-13 from T-motor for a Cinestar build, then later realized that the specs is calling for a 26-29.5 prop size in order pro it to work perfectly. Is it possible to fly it with APC Prop 16x5.5 MR/MRP, 18.5.5MR/MRP
  2. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    Even with 12s, the minimum prop size you could use would be 20" -22".
    So, no way to use 16-20" props on 6s setup with these motors.The motors will not generate enough lift.
