U8 and BL3.0 for Endurance Flying
Discussion in 'Electronics' started by Chris Fox, Mar 3, 2014.
  1. Chris Fox
    Chris Fox Active Member
    Apr 14, 2013
    463
    86
    Ok, so parts have started arriving for the next build, and I'm looking for a bit of advise, has anyone tried running the U8 motors with the new BL 3.0 controller?
    I'm interested in the regenerative braking and waypoint flying, hence trying MK again.
    If anyone has some experience with their trials they would like to share, that would be great ;)
    Cheers
    Chris
  2. Steve Maller
    Chris, what props are you planning to use? And are you going coax or flat?
  3. Chris Fox
    Apr 14, 2013
    463
    86
    G'Day Steve,
    I've just got my 28" props, so its going to be an x8 config.
    Cheers
    Chris
  4. Jason Eaton
    Jason Eaton New Member
    Sep 6, 2013
    29
    I gotta see this.... Make sure you rec bth....please.
  5. Chris Fox
    Apr 14, 2013
    463
    86
    Not a kopterworx frame ... an in house design and build.
    G'day Chris: Tell me you didn't just find some metal bed-frame out in the bush and decide to strap some tinnies of XXX to it.....and then get the whole lot airborne with U7's and 28" props....
    Chris Fox and Steve Maller like this.
  7. Adam Paugh
    Adam Paugh Distributor
    323
    78
    Hello Chris,
    I would encourage you to contact the support staff over at HiSystems-- support(at)hisystems.de with the details of your project (motor/prop combo).
    MK ESC v3.0 have proven to be...umm...particular to certain motors and props.
    Greetings,
    Adam
  8. Steve Maller
    If I was embarking on such a project, I’d be inclined to order a single BL 3.0 (not the full power distro board) and tether it to a bench with one motor and one prop and work out the timing and other settings. I think with such big motors and props, the likelihood of a electrical indiscretion of some sort taking out a $1000 board is pretty high if you’re running a full setup.
    http://www.quadrocopter.com/Single-BL-Ctrl-V30-2XL_p_1148.html
  9. Chris Fox
    Apr 14, 2013
    463
    86
    XXXX Andy XXXX .... and I'm not QLD, so normal folk don't go anywhere near that stuff ;)
  10. Chris Fox
    Apr 14, 2013
    463
    86
    Thanks for the heads up Adam,
    I just got a response back from HISystems, indicating that the U8 combination should be fine with the BL3 ....
    Now I just have to wait for some parts to come back from the machine shop to see ;)
    Cheers
  11. Steve Maller
    Those numbers for the U8 are rather staggering (including the price). Which (KV) model are you using? And what’s the targeted payload/mission? And don’t tell me it’s to lift 1/2 a Gaga. :D
  12. Chris Fox
    Apr 14, 2013
    463
    86
    Nope not interested in lifting anything gaga .... Looking to being able to fly long enough for HD broadcast, now we have the teradek bolt pro, so carrying camera head that can output 1080p at 422 colour (D800/Pocket or our 4K) for a reasonable time frame.
    Trying the higher KV rated motors, probably a couple of weeks before it is ready for flight testing ...
  13. Steve Maller
    Curious what a "reasonable time frame” ends up being...are you thinking 30+ minutes?
