Has anyone come across any solutions for mounting an iPad to the Tx? I can probably jerry-rig something together, but was curious if anyone had seen any products for this or done it themselves? I am using the Teradek Clip for my wireless video which transmits to an iPad, this is why I am curious.
check out this http://www.grifiti.com/products/nootle-ipad-air-tripod-mount-fits-any-tripod-or-light-stand if you have the Secraft Transmitter Tray with the monitor mount this will work perfect. You will need to drill the hole out a tiny bit bigger in the monitor bracket on the tray.
These guys also have a lot of mounting kits: http://www.shop.tethertools.com/Wallee-System-iPad-Accessories_c14.htm I use the Connect Lite and attach to a lot of different things with it (light stand, gorilla pod, neck strap, etc). You could probably fasten it to the back of your Secraft Transmitter Tray and be able to remove the iPad with a 90 degree twist when you want to take it somewhere else.
Nice ideas guys. I think I'll try to do something like you mentioned, Michael, with easy removability. Thanks!
