Trouble with paring Mimic to Movi Pro.
Discussion in 'MōVI Pro' started by Josh Park, Dec 2, 2016.
  1. Josh Park
    Josh Park Member
    Feb 16, 2016
    38
    19
    Hello, I just received Movi Pro today and have been messing around.
    I tried paring Mimic for the first time with Movi Pro but haven't been successful so far.
    I went to Movi Pro's Radio paring, set the channel to 3 on both Movi Pro and Mimic, and hit Pair. Waited until the process bar was complete, but the screen still says "Los." What does this mean?
    The manual doesn't explain much and I would much like a step by step guide. Thank you!
  2. Bryan Edmonds
    Jul 3, 2014
    254
    126
    Josh, go back to the main menu screen on the MIMIC and switch it from "off" to "MIMIC"
    Graham Futerfas likes this.
  3. Josh Park
    Josh Park Member
    Feb 16, 2016
    38
    19
    Yes I've done that as well. No change. What does "Los" mean on the radio status?
  4. Bryan Edmonds
    Jul 3, 2014
    254
    126
    Loss of Signal. Any time the mode on MIMIC is set to off, it will reflect LOS on the radio screen.
    For further troubleshooting, please contact us at support@freeflysystems. Images or videos of what you are experiencing will greatly boost our ability to help you.
  5. Graham Futerfas
    1,261
    245
    Hi Bryan, I'm having the same issue. The Mimic won't bind, and I see LOS on the Movi Pro under the Radio screen. I've tried different channels and different proximities with the Mimic. Did you and Josh find a solution?
    I can email you and send a video if you want. I turn the Mimic on, set it to 'Mimic' instead of 'Off', then go to Radio, set the channel on both Mimic and Movi Pro to the same, press Bind on the Movi Pro, then press Bind on the Mimic. They both have a Status Bar that runs for a few seconds, and then nothing. I see LOS on the Movi Pro and 'Select Channel and bind your MOVI Pro' on the Mimic.
    Anything I'm missing? I tried to follow the instructions in the Manual carefully.
    Thanks very much! I'll do a video and email it to you, but maybe it's worth posting the solution here on the forum?
  6. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    2 ideas
    1. What channel are you on? There might be an issue with channel 0
    2. Try power cycling the movi after setting the channel
    Hope that helps!
    SeBaStIaN BArrEtT likes this.
  7. Graham Futerfas
    1,261
    245
    Hi Tabb! Great meeting you today.
    Your advice helped... at first I tried Channels 0, 1, 2 and 3. I also tried powering things on and off a couple of times. After reading your comments, I tried channels 4 and 5, power cycling the Movi again, and it linked up on 5 straight away.
    Thanks very much!
    -Graham
  8. Graham Futerfas
    1,261
    245
    It may have been an issue with not letting the Mimic sit still for a few seconds. Looking back at my video I made of it last night, before it would bind, I had the Mimic in my hand the whole time and the Status never went from Red to Green because I kept moving it.
    I tried to bind again to a different channel this morning after letting it sit still on the ground for a few seconds and it worked. Silly me, I forgot the Mimic needs a moment to initialize, probably because the screen wakes up really fast and looks ready to go.
  9. Austin Larson
    Austin Larson New Member
    Dec 8, 2016
    Hey Guys,
    Still having trouble pairing up with the Pro and the Mimic.
    With Mimic on I have tried changing channels, rebooting both units, trying up close, trying far away, trying inside, outside etc...
    Basically i have tried everything listed above and am still having issues. I am only getting the LOS when attempting to bind both units simultaneously.
    Both units connect to the phone app with no issues.... Is anyone else having this problem? I have a Mimic Beta that i could try but i was hoping the Mimic would just link right up before i go that route
    Let me know if you have any other ideas.
    Austin
  10. Graham Futerfas
    1,261
    245
    Hi Austin, did you let it sit still for 5-10 seconds, until the little Status icon turns from red to green? I think that might have been my problem.
    Then switch from Off to Mimic, then try to bind, ideally getting a little distance between the units.
  11. Default mode is 'OFF'. The binding procedure is independent of what 'mode' it is in, though we do not recommend you change it to 'MIMIC' mode before you perform the binding process.
    If you have any further questions, please contact us at support@freeflysystems.com
  12. Tanner Wilson
    Tanner Wilson New Member
    Jun 12, 2014
    11
    Same binding issue. Tried at a distance, power cycled, tried channel 5, tried binding with no motion (not handheld) on the mimic.
  13. Graham Futerfas
    1,261
    245
    After you did the Bind, did you go back to the front screen and switch it to Mimic instead of Off? It will show LOS if it's in the Off position. And you got the green runner icon on the front page before binding?
  14. Rob Ruscher
    Rob Ruscher Member
    Nov 8, 2016
    80
    32
    I'm also having issues. Tried every channel and several reboots of both mimic and movi. Do you hit 'bind' from the movi or mimic? Have tried all the above advice
  15. Graham Futerfas
    1,261
    245
    I think you have to press Bind on both Movi and Mimic, but press it on the Movi first, then you have 5 seconds to press it on the Mimic.
  16. Rob Ruscher
    Rob Ruscher Member
    Nov 8, 2016
    80
    32
    I got to bind just before you wrote this and I'm sure that's what I did. Thanks!
  17. Graham Futerfas
    1,261
    245
    I think one of the unwritten steps in getting it to bind is... 'write to the Freefly Forum that you can't get the Mimic to Bind' and then go back and try a few more times. Seems to be working for people. :)
    Rob Ruscher and Bryan Edmonds like this.
  18. Daniel Díaz
    Daniel Díaz New Member
    Jul 19, 2015
    11
    Same issue here. I've tried all these steps with no result. :confused:
  19. Kurt Wallrath
    Kurt Wallrath Member
    Nov 8, 2013
    138
    21
    Here's what worked for me to bind the Movi Pro with the Mimic Pro:
    -Make sure both Movi and Mimic are on the same channel (channel 1 worked for me)
    -Make sure Movi Pro is on Majestic Angle and not Smooth Lock
    -Press "bind" on Movi Pro with the Mimic an arms length away then walk 3-5 steps away
    -Press bind on Mimic Pro
    Hope that helps
    Daniel Díaz likes this.
  20. Daniel Díaz
    Jul 19, 2015
    11
    Thanks very much Kurt, I've done what you've said but it doesn't work.
