Trouble loading NEW Firmware for Mimic Pro
Discussion in 'MōVI Pro' started by Arnold Kaplan, Jan 31, 2017.
  1. Arnold Kaplan
    Arnold Kaplan New Member
    Jan 18, 2017
    Hi,
    Im trying to load Mimic Pro firmware v1.1
    But the process stops halfway through and says "un oh failed to enter boot strap mode please power cycle and try again"
    which I have a few times and when I do the progress bar(second bar at the bottom) is shown being about 30-40 percent complete
    Updated Movi pro software no problem just having problems loading the Mimic software
    Any help would be appreciated!
  2. Deniz Ozgoren
    Deniz Ozgoren Support Mage
    Dec 17, 2015
    273
    84
    Are you trying with Android or iOS? Can you share os version and hardware model for it?
    Have you tried rebooting your tablet/phone?
  3. Arnold Kaplan
    Jan 18, 2017
    Appreciate your reply Deniz
    iPhone 6plus iOS 10.2.1
    Yea, I did reboot
    Maybe delete and reinstall ??
  4. Deniz Ozgoren
    Dec 17, 2015
    273
    84
    Is MIMIC stuck with black screen or when you repower you can use MIMIC as usual?
    I doubt it will help but you can try delete and reinstall. You can also try "revert" instead of update and let me know if that one works..
  5. Arnold Kaplan
    Jan 18, 2017
    Yep, it gets stuck on a black screen with only the green indicator on
    In order to use it I have to hold the power button down so the green light goes away then re-press the button to start the unit
    I tried the revert process and its still getting stuck and comes displays that error
    Im going to try and delete and reinstall the software and see when it goes
    Thanks!
  6. Graham Futerfas
    1,261
    245
    Maybe this isn't the cause of your problem, but this happened to me when I was updating yesterday, and I found that I had the Movi on while I was trying to update the Mimic. My iPhone jumped over to connect with the Movi in the middle of the update and lost connection with the Mimic, and the Mimic had the black screen with Green LED. So I had to start over and turn the Movi off.
    Could there be any bluetooth interference or other devices grabbing on to your phone?
  7. Deniz Ozgoren
    Dec 17, 2015
    273
    84
    @Arnold Kaplan, you might want to contact support directly for RMA.. I can't think of a solution at the moment. Tried many different scenarios already. http://freeflysystems.com/contact
    @Graham Futerfas, I am not sure if thats possible. iOS App will auto-reconnect only to the last connected device.. It uses unique ID to do this so interference shouldn't be an issue. I tried reproducing in different ways just in case as well but couldn't.. Are you 100% positive that you started fw update on MIMIC via your iPhone and then found it to be connected to your MōVI instead (automagically) after a while?
  8. Graham Futerfas
    1,261
    245
    Hi Deniz, I should have been more careful about documenting it. You may be correct, looking back at my setup now. The update seemed to have frozen, and when I looked at the iPhone, it was not connected to the Mimic, but if you tap Connect, there are blue lights next to Movi Pro indicating signal. I may have mistaken that for a connection.
    After turning off the Movi and starting over, the update went through, but that could be coincidence.
