Trouble ironing out the bumps with a7rii GM_24-70
Discussion in 'MōVI M5' started by Anthony Shorten, Sep 6, 2016.
  1. Anthony Shorten
    Anthony Shorten New Member
    May 28, 2013
    24
    Hi Guys,
    We have spent days out in the field fine tuning our new m5 after loosing our last one to Poseidon. We had the old m5 working flawlessly with the new firmware and are having trouble achieving similar results with the new rig.
    here is a youtube video of the bumps
    We have tried adjusting stiffness, gyro filters, hold strength, isolators, copters (x8/ flat 8), steadyshot on/off, different camera firmwares
    Here is a screenshot of the settings we ended up with
    with steady shot on @24mm
    Would appreciate any help as we are running out of ideas.
    Cheers!
    Anthony when you tune the the MoVI consider hanging the copter from a center point off of the ground and then do the tuning. It's always best to do the tuning the way you are going to use the MoVI.
  3. Anthony Shorten
    May 28, 2013
    24
    Hi Gary,
    All of our tuning is done with the wifi adaptor while the movi is under the copter in flight. Pan/tilt and roll have all been balanced. We are leaning towards it being a isolation issue, but am open to any other ideas :)
    Cheers
  4. Gary Haynes
    Anthony I think you have broken new ground. I don't think anyone has ever posted that they tune while airborne.
  5. Anthony Shorten
    May 28, 2013
    24
    haha really Gary?
    we thought that tuning in flight made the most sense - may as well tune in the conditions it will be operating in :)
  6. Gary Haynes
    You might want to try simply hanging it on the ground. I'd guess that you will get higher values. While in the air you have introduced all types of additional forces. Typically tuning is while the MoVI is nearly stationary.
  7. Andy Johnson-Laird
    10,354
    1,160
    I agree with Gary....my first reaction is that it's going to be trying to autotune to a moving target (literally and metaphorically!).
  8. Richard Boghosian
    Richard Boghosian New Member
    Sep 13, 2016
    How about utilizing a 24mm prime lens.?
