Toad Problems
Discussion in 'MōVI M5' started by Andrew Gough, Apr 20, 2016.
  1. Andrew Gough
    Andrew Gough New Member
    Mar 14, 2014
    Hello,
    I apologize if this has been discussed before, I did search the forum. I have a toad in the hole on my M5 and when I use upside down I am getting a slight clunk or looseness in the toad. It is ok when used in the normal orientation, but with the gimbal reversed, it clunks. I have tried a couple of different male connectors, but it still does it. All screws are tight and I tightened the lever as much as I could with it still going over centre to lock.
    Any ideas?
    Andrew
    Hi Andrew:
    I suspect the best thing to do is open up a support ticket by emailing to support@freeflysystems.com -- I don't recall the issue you're having as being reported on the forum.
  3. Andrew Gough
    Mar 14, 2014
    Hi Andy,
    I have sent the email to Freely. I'll report back what the solutions is.
    Andrew
  4. Ty Frey
    Ty Frey New Member
    Sep 23, 2016
    Andrew - ever get the issue sorted?
