Toad on MR and CS8?
Discussion in 'MōVI MR' started by Mike Peters, Mar 20, 2015.
  1. Mike Peters
    Mike Peters Member
    Apr 4, 2013
    45
    Sorry if this has been asked elsewhere, but I didn't find an answer.
    I'm about to buy a MoVI and want to use the Toad in the Hole to make it easy to switch between hand held and multi-copter (CS8). It appears from everything I've read, that the MR legs would stay attached when the handle is attached via the male toad. Is this correct? How cumbersome is it to operate in handheld mode with the legs still attached?
    Mike
  2. Jeff Scholl
    Jeff Scholl Distributor
    240
    50
    Flip the handbars 180 so the grips are sticking up and you will have zero interference with the legs. Also you are ready to shoot vertical mode if you want higher reaches from the ground.
    Jeff
  3. Janne Hoglund
    Janne Hoglund Member
    Oct 4, 2012
    364
    23
    I use retracts instead of the standard FF legs. Much better in ever way I think :)
    And yes the Toad is an awesome thingi!
    Tabb, when will FF make Cinestar retracts of their own?
    Regards from Sweden.
    Mark McGuire and MIke Magee like this.
