Toad In the Hole
Discussion in 'MōVI M5' started by Tristan Twisselman, Jul 25, 2014.
  1. Tristan Twisselman
    Jun 30, 2012
    416
    25
    I noticed my Toad in the hole once clamped down still has play and isn't tight enough. The bolt that goes through the little clamping handle to tighten it is stuck in there. I tried loosening it when I first got it this week and it wouldn't loosen or tighten and i don't want to snap the bolt head off in it. Anyone else experienced this?
  2. Tristan Twisselman
    Jun 30, 2012
    416
    25
    Quadrocopter is gonna warranty it for me. It is definitely a must have accessory
  3. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    Once the hole is clamped to the toad you shouldn't have any play but if you do you can tighten the bolt that is located at the hinge point of the clamp. Not sure how yours could be stuck. I just thought I would answer in case anyone else runs across this issue.
    Andrew Griffiths likes this.
  4. Jason Comparetto
    Sep 23, 2013
    269
    38
    Were you able to fix this?
