When i clip my toad into the hole and push the clamp down to lock it in place, i can be holding onto the handle bars and if acting like i am steering the movi like you would a steering wheel left and right there is play that I can not get rid of. The clamp is as tight as it can get and every other bolt on the toad and the hole are tight. Thoughts? Anyone else seen this issue? I had the same issue with my last toad in the hole and it was because the set screw for the clamp was stripped and couldn't be tightened. This one is as tight as it can get and still be able to close the clamp and i still have play.
Tristan if you have already done the tensioning adjustment then I would suggest sending a note to support@freeflysystems.com. Maybe it is a bad Hole.
Thats what i thought guys, I just don't get why it is like this and the fact i just returned one for a similar issue. Ill shoot freefly support an email. Thanks fellas.
