Toad for Jib?
Discussion in 'MōVI M10' started by Derek Cooper, Feb 22, 2015.
  1. Derek Cooper
    Derek Cooper Active Member
    Apr 28, 2014
    527
    34
    Any experience out there attaching a Freefly toad to a jib underslung in a 100mm bowl?
  2. Nicolas Teeuwen
    Jan 15, 2014
    162
    23
    Nope, but make sure it is mounted well. I had my toad come detached. I suspect I hadn't fully engaged the leaver with a cable stuck in it that got pulled free. I then suspect further tangling of the cables pushes the saftey buttons. Someone else also experienced a detach. Keep the toad cable free. You would not want that falling off a jib.
  3. Derek Cooper
    Apr 28, 2014
    527
    34
    Ouch - nasty!
    I think what we are going to try is tap one side of a 1/2" thick aluminum billet with a 3/8" 16 screw hole. That will screw onto a half ball mounted in an inverted bowl. The reverse side of the billet we will tap 4 M3 screw holes and attach the toad.
    We will see if it works - will send pics.
