Time-lapse with the M10 long time exposures
Discussion in 'MōVI M10' started by Adi Geisegger, Jan 2, 2018.
  1. Adi Geisegger
    Adi Geisegger New Member
    Dec 19, 2014
    Hello,
    I have a question about the time-lapse function on the Mövi?
    When i set the time-lapse mode to interval for example 10 sec.
    make the mövi the movement every 10 sec. or is this only for calculating for the images?
    I ask but I will make long time exposures;-)
    Many thanks Adi
  2. Graham Futerfas
    Graham Futerfas Active Member
    788
    168
    I believe the Movi moves at a constant speed, and the Interval is merely so it can calculate how fast to make the move. That said, you should definitely test it, and you could contact Freefly Support for a definitive answer of how it works 'under the hood', so to speak.
    If you're doing really long exposures, keep in mind that the gimbal is more susceptible to wind gusts and external factors than a tripod.
    SeBaStIaN BArrEtT likes this.
