Hi, I'm calibrating my Movi and getting good numbers with pan and roll stiffness, but for tilt the Freefly Config App doesn't seem to be communicating with the motor. I've taken it up to 500 - nothing. And in pushing the tilt up and down there is absolutely no resistance, like the motor is off. Any advice? Thank you, Jacob
First thing is to check and make sure the wire leading to the motor is properly seated. These connectors can deceive you into thinking they are in all the way when they are not, so give them a gentle, yet forceful push. Use a spudger if you have one. If that doesn't work, you may need to check with support@freeflysystems.com for further troubleshooting.
Check to see that the Tilt motor connector is full plugged in. It takes a very firm push to get it full seated. You might need to remove the safety cover to get to it. Same thing on the IMU.
Indeed, it wasn't properly seated and plugged in. Thank you very, very much. Just got this thing and perhaps a little impatient to rock n roll with it.
