Tilt offsets
Discussion in 'MōVI Pro' started by Pete Maughan, Aug 18, 2019.
  1. Pete Maughan
    Pete Maughan Member
    Mar 1, 2014
    75
    11
    Are people just installing the offsets and keeping them on or fitting and removing as required?
  2. Graham Futerfas
    1,261
    245
    I keep mine on. They’re a bit risky to install, because you have to disconnect the tilt stage cable, and a few people apparently have shorted out their Movi this way.
    I really like them! They’re a smart way of reducing the amount of counterbalance you need, because they move the cage back an inch and use that as counterweight, as well as allow more room below the camera for lens motors.
  3. Pete Maughan
    Pete Maughan Member
    Mar 1, 2014
    75
    11
    Thanks Graham, I’ve added and removed a few times but thinking its best just to fit and forget.
  4. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    We just keep them all the time on the gimbal.
  5. Rick Gerard
    Rick Gerard Active Member
    Apr 22, 2017
    172
    27
    I have not found any camera that will fit in the cage that I cannot balance with tilt offsets. A Sony A7 III with a 50mm SLR Magic and a single FIZ motor is the lightest setup and a Terra 4K with a Fujinon 50 - 135 + 3 FIZ + Teradek Bolt in the cage was probably the heaviest and longest. The Cinemilled baseplate is also highly recommended.
  6. Sean Jensen
    Sean Jensen New Member
    Jul 11, 2015
    I've just finished a series for Netflix where we used the MoVI Pro as a remote head on our crane. I had an almost impossible time balancing our camera until I got the offsets. RED Monstro, Panavision G series anamorphic lenses, Bright Tangerine Misfit Atom Matte Box, Preston MDR4, 2x Heden motors, Preston Light Ranger 2 and a Teredek Bolt 2000. I also went with IgniteDigi's TB50 battery adapters and the accessory mounts as well. System worked perfectly.
    #6 Sean Jensen, Dec 22, 2019
  7. Graham Futerfas
    1,261
    245
    I also really like those counterweight brackets you have from Ignite Digi. They make it easy to keep the counterweights inside the camera body area and away from hitting the Roll Beam, and you can use your transmitter as counterweight if you bolt it to it.
    Definitely look at the Abracam matte boxes. I sold my Misfit Atom after switching to the Abracam because of the easier-to-add Eyebrow and the ability to take a 4.5" round filter and rotate it (for Pola's and Diopters, mostly).
    Rolands Zelders likes this.
  8. Sean Jensen
    Jul 11, 2015
    Those offsets are great and that's exactly where I attached the transmitter. I recently purchased the Misfit Atom + Pola matte box. It wasn't available when I got the Misfit Atom. I can use the same eyebrow too. It solves the Pola/diopter problem for sure. Those Abracam matte boxes look interesting. Similar pricing too, I believe, but more variety.
