Tilt Motor Overheat
Discussion in 'MōVI Pro' started by Guilherme Costa, Nov 21, 2018.
  1. Guilherme Costa
    Guilherme Costa New Member
    Jun 14, 2018
    Tilt motor is now overheating, I am on my way to see it, but as described I think the tilt motor may be gone.
    Any troubleshot walk-trought available for diagnosis?
    Thanks.
  2. Graham Futerfas
    1,252
    241
    You can use the Monitor charts in the app to look at some of the parameters. Often it's due to an unbalanced gimbal, and usually it will cool down and recover on its own.
  3. Guilherme Costa
    Jun 14, 2018
    The gimbal is balanced. Now with a light 5D. An even so, overheating and the motor loses power.
  4. Guilherme Costa
    Jun 14, 2018
    It is balanced with a 5D now. And it seems that has some spikes, when the tilt got crazy with no movement.
    https://imgur.com/a/iRLOhT6
  5. Andy Johnson-Laird
    10,381
    Hi Guilherme:
    Sorry to hear about the issue you're having. I suspect you need to open up a ticket with Freefly Support and the best way of doing that is to head over to https://freeflysystems.com/contact
