Tilt Majestic Angle Limit
Discussion in 'MōVI M5' started by reto weiss, Jul 19, 2015.
  1. reto weiss
    reto weiss New Member
    Dec 7, 2012
    26
    For aerial ortho photos, I want to use my M5 aboard a multicopter with tilt majestic angle mode.
    However, even with full tilt "down" command, the gimbal only tilts down about 45°, not more.
    Why?
    In tilt majestic smooth lock mode, the gimbal tilts to the min tilt angle currently set to -110°, without any problem.
    I'm using a Futaba RC with SBUS2.
    Why is the min tilt limited to -45°, any ideas?
    10,357
    1,161
    Hi hover, welcome to the forum.
    As to why the limitation, you might want to email directly to Freefly at support@freeflysystem.com -- I don't think I've ever seen the written rationale for it.
  3. reto weiss
    Dec 7, 2012
    26
  4. Gary Haynes
    Check the Max and Min Tilt Angle settings.
  5. reto weiss
    Dec 7, 2012
    26
    min angle = -110, max angle = 45 - should be fine and works in majestic smoothing mode.
  6. Gary Haynes
    Change the value in the max angle to 90 or 110 depending on whether you want to go past vertical.
  7. reto weiss
    Dec 7, 2012
    26
    Let´s talk about tilt ANGLE mode first:
    Although the min angle is set to -90 or even -110, the gimbal doesn´t tilt more than -45 degrees. Why?
    Watch this:
  8. Gary Haynes
    Your max tilt is set at 35. And looks like it is stopping exactly where you programmed it, 35 degrees down. Change the value to 90 and try it again. The - is up angle, positive is down angle.
  9. reto weiss
    Dec 7, 2012
    26
    I tried it out, but from what I see, MIN = NEGATIVE = DOWN ANGLE, MAX = POSITIVE = UP ANGLE.
    In SMOOTH LOCK mode, I can point down 90° and up 35°, the limits seem to be ok, I appologize.
  10. reto weiss
    Dec 7, 2012
    26
    I double-checked with the manual, 04-P23:
    Max Tilt Angle - Sets the maximum angle of the Tilt Axis when looking up. Use to set soft-stops to prevent the camera or lens from hitting the gimbal, or to prevent wires from being pulled out.
    Min Tilt Angle - Sets the minimum angle of the Tilt Axis when looking down. Use to set soft-stops to prevent the camera or lens from hitting the gimbal, or to prevent wires from being pulled out.
    How shall I understand your proposal to increase the max tilt angle from 35 to 90 in order to change the tilt limit when looking down?
    I'm pretty confused.
