Tilt issue please help
Discussion in 'MōVI M5' started by Wilson Milley, Oct 18, 2015.
  1. Wilson Milley
    Wilson Milley New Member
    Jun 23, 2014
    I have 2 M5's both set up with a panasonic GH4 and 7-14mm one of them I am having problems with the tilt level. When I tilt up and I go back down it does not come back to level
    the camera still points up maybe 5-8 degrees I have to tilt forward then it will come back to level. The level does come back if I tilt down first then come back up, just not when I tilt up and go back to try to get level. I have both M5's set up exactly the same and have balanced both. I have tried numerous configurations but the one will just not come back to level
    10,364
    Hmm. It sounds like it's time for an email to support@freeflysystems.com -- the fact that two M5's with the exact same configuration behave differently doesn't sound right.
    I presume you're using the same remote controller/MōVI controller when you test?
  3. Wilson Milley
    Jun 23, 2014
    All handheld never use a controller.
  4. Gary Haynes
    Wilson can you post all of your tilt settings?
  5. Wilson Milley
    Jun 23, 2014
    Tilt Stiffness 12
    Tilt Hold 8
  6. Gary Haynes
    Also need your Majestic Config Tilt settings please. If the settings and setup for both of your M5's are the same with the same camera setup then it might be a sensor issue. Might be worth opening a ticket with support@freeflysystems.com.
