This has just recently happened to me, but continues to happen. It mostly happens when I am in Smooth Lock mode. I will go to adjust the tilt manually either up or down, and when I move the camera it goes limp and loses its lock, almost like a gyro failed. But when I go to look as all the plugs they are secure. Does anyone else have this issue?
Can you save the M10 gimbal control settings to a .cfg file on your computer, and check the Tilt Hold Strength settings, Kevin? The .cfg file is plain text. You can even post it on the forum if you wish. Andy.
