Tilt Bearing Issues
Discussion in '3 Axis Gimbal' started by Matt McTurk, Sep 18, 2013.
  1. Matt McTurk
    Matt McTurk New Member
    Oct 6, 2012
    15
    I was playing around with my 360 Gimbal and noticed that there seems to be some friction in the bearings for my tilt. I took the belt off to verify it wasn`t the motor, and I still had the problem. Based on that, I am assuming it is the 2 bearings on the tilt mount. My question is does anyone know what the bearing size is, and if I can just press in new bearings in those spots? I just want to be able to buy bearings from my local supplier as I don't want to wait for 2 bearings to come from the USA (I'm in Canada). Any ideas would be appreciated. Thanks
    Matt: Before you replace anything, loosen the screws holding the bearing on the right hand side (viewed from the rear) of the gimbal to the point that it can rotate around the boom. You might also need to do the same thing on the left hand side (viewed from the rear) as well.
    Sometimes what can happen is that the bearings get tweaked and are not actually parallel or actually on the same axis and that creates that resistance you're describing. Loosening the right hand one will often allow the bearing to self-adjust and come back into alignment.
    Let me know if this helps.
  3. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    It's either the bearings or it could be that the shaft mounts have been rotated on the tube causing friction. If the shaft on the left and on the right aren't perfectly aligned that could be causing fiction
  4. Brad Meier
    Aug 14, 2012
    749
    66
    What he said
  5. Matt McTurk
    Oct 6, 2012
    15
    Hey Guys Thank You very much. I never did think about the potential for misalignment. I did exactly what you said and it works fine now. I hope you guys never retire from this forum cause your a wealth of knowledge that can't be replaced.
  6. Brad Meier
    Aug 14, 2012
    749
    66
    Excellent! Usually the simplest option is the best.
  7. Andy Johnson-Laird
    Glad we were able to help.
