I' My tilt wont reach 90 deg. facing the ground. It goes almost not 40 deg. Is it possible to set this? Martin
Martin what are you using for tilt control? If you are using the Radians the is a min and max angle setting in the software that you can adjust.
Yes i use radian. But i'll maybe bluind...i did not see where to set it. I probably look like a boy. Martin
Martin first check the firmware version that you have installed using the bootloader software. You need to be on version 1.03. The earlier version did not have the min/max angle. Here's what a 1.03 screen should look like and you can see the Min/Max angles in the middle of the right Configuration screen.
I finaly get to instal the 1.03 firmware...but still the same hold screen whitout angle limite. and i just found out that your radian stabilisation program is 1.1...mine is 1.0 and i can't install the new version... ill try again.
tank's...a finaly et the 1.1 software version...! :-(...i had a hard time cause i extract it in the download folder a try to instal it from there but no good... I was righting you a message to explaine what was my probleme when i realised my error. So everiting works good now.
