Anyone have a base Throttle Setting for: 2 x 10,000mah 6S 25C Lipos and 2 x 10,000mah 6S 25C Lipos + M15, Epic, 15lbs Payload Just trying to get a base to work with and go from there.
Rory try the default setting. Simply takeoff, hover and check the position of your throttle. Above center add some voltage (increase). Below center reduce. Quick to do. Land, kill motors. Use the app to make the adjustment. If its close to center, say a notch off on the Futaba try .2-.3 change.
