The best battery charger to charge multiple packs ?
Discussion in 'Cinestar 6' started by Jason Herring, Jun 29, 2013.
  1. Jason Herring
    Jason Herring Member
    Apr 7, 2013
    278
    Hi,
    I'm running 4s 6000 in paralell , and bought more batterys and now I'm looking for a charger that I can charge multiple packs at the same time, currently I'm using 2 Ac /Dc chargers, it would be so nice to charge 4 at a time,
    Thanks,
    Jason
  2. Howard Dapp
    Howard Dapp Active Member
    Aug 18, 2012
    977
    111
  3. Jason Herring
    Apr 7, 2013
    278
    That looks great, with the paralell cable connected and 8 packs how do you hook up a balancer for all 8 packs? What amount of time does it take to charge all of those packs? 4s? How many mah are you using?
  4. kjetil tønnesen
    Aug 16, 2012
    417
    23
  5. Sam Fleishman
    Sam Fleishman Member
    Mar 30, 2013
    211
    17
    Trent Lewis likes this.
  6. kjetil tønnesen
    Aug 16, 2012
    417
    23
    tes we love this one:)
  7. Mateusz Hajdziony
    Jul 10, 2013
    80
    Sorry for posting in this old thread. Just wanted to let you guys know that iCharger 4010 Duo is an absolute beast. It has two asynchronous channels, delivers up to 2000W of power and comes with these little balance boards, where you can connect two 4S, two 5S, three 3S (and so on) packs in series. You could charge four 4S packs at a time. :)
  8. Gary Haynes
    Mateusz totally agree. Challenge as I was looking at them was finding a large enough power supply to get the full benefit. In the states ProgressiveRC has a 2000W 48V Mean Well power supply but in reality it will only get you 40amps on one side and something much less on the other. So not sure how you would power 40a out of both ports without a nuclear plant under the charging stand :)
  9. Mateusz Hajdziony
    Jul 10, 2013
    80
    That's a legitimate concern Gary. I already have the charger but haven't bought the planned 7S packs yet, so for now I use a regular ATX PSU to charge my 3S packs. Once I have the 7S packs, I'm planning to use a server PSU - HP ESP120 - with slight modifications to drop output voltage just a little bit. It can give up to 3000W of power and is really cheap (seen used ones on eBay for something like $40). There are threads on RCGroups where people post pinouts and modifications needed to drop voltage. :)
  10. Gary Haynes
    Yep I saw those as i was thinking about a different charger. But with the amount invested in batteries and the charger I am just skeptical about wiring 3 or 4 of the HP PSU's together. And then trying to find a 110v 20amp circuit since most places are 15amps. And the overall size if you travel with your equipment. For only losing 10amps the iCharger 306b looks interesting. Or the FMA Powerlab 8 V2 at 40amps. Both are less expensive.
  11. Jason Toth
    Jason Toth Active Member
    May 11, 2013
    312
    46
  12. Maxis Gamez
    Maxis Gamez Member
    Jul 1, 2013
    60
    This is very informative. Thank you all for sharing! I ordered one.
  13. Howard Dapp
    Aug 18, 2012
    977
    111
    Gary, which power supply and charger did you end up going with? Are you charging 6s packs?
  14. Gary Haynes
    Powerlab PL8 with the eFuel 1200. I can charge 2 6S at a time, 2C rate, using the Revolectrix/Powerlab MPA boards. The MPA boards are built like tanks with full fusing on all circuits.
  15. Howard Dapp
    Aug 18, 2012
    977
    111
    Nice, this is your setup here?
  16. Gary Haynes
    That's the setup. I also bought the USB dongle and drive everything from the computer unless I am remote. Packs are all FF9000's. I try to keep the total charge AMPS running at 36 or so and the eFuel does a good job. Much more than that it runs out of oomph.
  17. Derek Cooper
    Derek Cooper Active Member
    Apr 28, 2014
    527
    34
    Gary - still using the eFuel 1200? Read some reports people have run into problems when using the Revolectrix chargers with them - seems some of the newer eFuel power supplies are spiking on startup?
    Did you consider the Revolectrix Power Station in your initial research?
  18. Gary Haynes
    Haven't had any problem with the eFuels and the PowerLab8. I did try one of their chargers and sent it back. Fan sounded like a jet engine. And I need duals since I use two PowerLab8's.
  19. Derek Cooper
    Apr 28, 2014
    527
    34
    Nice - ok.
    Clarification - do you mean you tried one of the Revolectrix power supplies?
  20. Gary Haynes
    Yes I tried one of the Revolectrix's.
