Hi everyone. I'm trying to do a little maintenance on a u-7, and I can't seem to get it apart. I've taken off the screw at the bottom of the motor, and the two set screws inside the top of the motor, and I just can't get the bell off. There is a small piece of metal in there I need to take out, and I can't tell if I need a press or what trick I need to separate the bottom of the motor from the bell. Any tips or advice? Thanks as always. Steve
it's been awhile but isn't there a spring clip on the shaft on the bottom of the motor? Not sure about the U7 but most motors are made this way.
I've tried making a makeshift press out of a few screws and plates, I've tried tapping on the center post there (gently)... tried prying and pulling and no movement on the bell at all. I'm kinda stumped... I took the set screws out of the top inner shaft... and it seems like I should be able to pull it apart... but nothing on the web to show me how to take the thing apart.
Looks like the bearing might have been hot/cold pressed into the housing, perhaps, Steven? Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limitâ„¢ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
