Start/Stop Function
Discussion in 'MōVI Controller' started by Kevin Descheemaeker, Oct 22, 2014.
  1. Kevin Descheemaeker
    Sep 16, 2013
    59
    Hi
    We bought the MōVI controller and so far everything works fine, but now we are searching the best solution to make the start/stop function work.
    We use the Micro remote set with our RED EPIC camera on the MōVI. What are the cables we have to buy to let this setup work? We saw at the RedRock site the "run/stop Red cable" with Part 2-100-0038 in combination with the BNC sync cable of RED.
    This will probably the way of working but to us it seems like a bunch of cables strapped on de MoVI. Is there a solution with one cable?
    Any suggestion is welcome!
    Many thanks
    Kevin
  2. Derek Cooper
    Derek Cooper Active Member
    Apr 28, 2014
    527
    34
  3. Jonathan Ross
    Jonathan Ross Member
    Jul 29, 2014
    113
    10
    Installed ours today and worked like a charm first time.
  4. Austin Glass
    Austin Glass Active Member
    Aug 1, 2013
    440
    69
    Derek or Jonathan, can either of you verify that this works with the RED? What additional cables are needed?
    Kevin Descheemaeker likes this.
  5. Jonathan Ross
    Jul 29, 2014
    113
    10
    Hi Austin,
    We are using ours on a Cannon 5D mark 3, I am sorry we can't help you with the Red. Best of luck.
    Cheers,
    J
  6. Kevin Descheemaeker
    Sep 16, 2013
    59
    Hi Jonathan, Derek and Austin
    I don't thin the quadcopter cable will do the job for the RED Epic, RED is always something special.
    Austin are you using the MōVI controller ass well? How do you use the rec button on it in combination
    with the RED EPIC?
    Grtz
    Kevin
  7. Austin Glass
    Aug 1, 2013
    440
    69
    The Controller's rec button does not currently function the way I have it set up, but whispers suggest an upcoming firmware update will allow it to start/stop the camera the same way the microRemote/Axis1's hand controller does.
  8. Kevin Descheemaeker
    Sep 16, 2013
    59
    [​IMG]
    Chris Harrison (Freefly Systems)
    Nov 11 10:54 AM
    Kevin,
    Thank you for contacting Freefly and MoVI technical support. Unfortunately Freefly has not yet released compatible camera specific cables for the RED, etc. We are looking to have several cables available very soon. Quadrocopter has developed a cable independently from Freefly. We do not know if it is specific to the RED cameras, so you will need to contact them directly for more information. As soon as we have camera specific cables available, we will announce it on our Freefly forum, Facebook page, and to pre-existing newsletter subscribers.
    Please let me know if you have any other questions.
    Best regards,
    Chris Harrison
    Freefly/MoVI Technical Support
  9. Chris Boots
    Chris Boots New Member
    Apr 16, 2014
    20
  10. Even Sigstad
    Even Sigstad New Member
    Jan 2, 2014
    23
    10
    Yup, the quadrocopter start/stop cable ande the gentLED cable works perfectly with the Red
  11. Kevin Descheemaeker
    Sep 16, 2013
    59
    Hey Even & Chris
    Thanks for the tip! We gonna order the cables and try to work it out!
    Grtz
    Kevin
  12. Even Sigstad
    Jan 2, 2014
    23
    10
    Its easy to set up, just remember to change the shutter button setting on the controller to "toggle" and you should be all good :)
  13. Kevin Descheemaeker
    Sep 16, 2013
    59
    Hey Guys
    The cables arrived and everything works well! Thanks again for the advice on it!
  14. Derek Cooper
    Apr 28, 2014
    527
    34
    Excellent news Kevin!
  15. Chris Boots
    Apr 16, 2014
    20
    Glad to hear it's working out for you Kevin.
  16. Jonathan Ross
    Jul 29, 2014
    113
    10
    Our new stop/start is working however we have to push the button twice to turn on and off.
  17. Chris Boots
    Apr 16, 2014
    20
    Interesting. Tell me about your setup. Never had an issue like that with any of the shutters we've testing the past.
    Jonathan Ross likes this.
  18. Jonathan Ross
    Jul 29, 2014
    113
    10
    Hi Chris,
    We have a Movi M5 going to a Canon 5d 3 plugged into the s-bus port. We are using the Movi controller set to toggle. Is that enough info? We sent it back to you with problems you said it worked fine and then we get it back and it takes two pushes. of the button to activate. Ned Frisk is my pilot that placed the order with you Chris. Thanks for any help we are good with pushing it twice just don't know why i's happening.
    Cheers,
    J
  19. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    Chances are you have the start/stop button set incorrectly. Options are toggle or momentary.. Try changing that setting to the other.
  20. Jonathan Ross
    Jul 29, 2014
    113
    10
    Thanks Brad I'll check that tomorrow sure appreciate the help.
    Cheers,
    J
