Hi, Is there a way to trigger the Black magic 4K cinema camera from the moVi controler ? Same question with the canon 5D mark. I have seen that these controls will be available thru an option (3 channels FIZ system) is there any release date ? Menwhile is there a simple way to trigger the start/stop function of the 4K ? I have seen that camremote may di the trick (there are a few minors bugs yet) but how can it be plugged to the movi controler receiver ? best regards, Cedric
Jason Toth over at www.rvrd.com mentioned that he has that working wirelessly on their BMPC 4K cams. I'd be curious too! Will the Controller's FIZ solution be an electronic wireless LANC implementation?
Hi Derek, I know gentled and I was expecting to use it with the MoVi controler but despite my requests, I still don't know if it's compatible with the MoVi controler and how to plug it.
Cedric, Have you looked into this new cable at Quadrocopter? http://forum.freeflysystems.com/ind...utter-with-mōvi-controller-now-possible.5191/ I'm guessing that's what you need? If you talk to Quad, let us know what they say. Derek
