Turn off the 'Mode' channel using the PC software and the module will be in stabilised mode as long as it has a valid slew channel. If it doesn't have slew then it will go into 'fixed angle' mode. This is what most people use for the roll axis as they want it level all the time. Apart from that, you connect it as Tabb shows in the videos. Remember that you need the mode channel if you have pan stabilisation on the freefly mount because it will spin on the ground if you don't turn it 'off'.
Or just plug in power, set default orientation, and then set gain. You can even skip the slew channel if you do not intend to use it. Tabb
Ok so if i only gunna use tilt and stabilization i just run one wire from the tilt to the reciver and it will power both radians?
Each Radian would need some sort of power source. If you only want to control tilt you can run a lead into the Tilt Radian Input and then just a power lead (either from the BEC or from the tilt radian back to the roll radian) Hope the helps Tabb
