Happy New Year, everyone! I've got a problem, hoping it's a simple one......Movi Pro, Spektrum DX7S, AR7000 Receiver. All worked great three months ago. Everything got put away, now no Movi control. Light comes on on the receiver when the Spektrum is turned on but no control. Set the controller to DSM2 1048 and DSM2 2048, with the app, nothing with either. Any idea's?
I could be mistaken, but I was under the impression you needed an 8-channel receiver for Movi Pro, like AR7700 or AR8000. That said, if it was working three months ago... Are you plugged into COM 2 with your receiver? And you've switched the Dual Op\Majestic\Kill Switch on the DX7s to Dual Op? If you go in to the app on your phone, and look up Monitor->Charts->Radio, do you see anything move on the graph when you try things on the controller? Have you checked the channel mapping on both Movi Pro and in your Spektrum Controller Menu? There's channel mapping info in the Movi Pro User Guide.
Thanks, Graham......Plugged into Com 2. The controller does not have anything marked Dual Op/Majestic/Kill Switch. I went into the app and check the graph, it's flat lined. I checked the mapping and it's on 6, where I left it three months ago. Damn, it has to be something simple!
You need to switch to Dual Op on the controller. It’s not marked. It’s a three way toggle switch on the upper right. Needs to switch up to dual op, middle for Majestic, and down for Kill.
Sorry, I mean Upper Left side of the DX7s. Just pulled mine out. It's the second switch in from the left.
Just put that switch in the middle position, nothing! I set my radio type to DSMX 2048 as well. Can't figure this out, why would it change. Went to TB50 batteries, thats the only difference.
The switch which is second from the left is in the up position.....no luck. Also, tried all the other positions too.
