Spektrum DX6i
Discussion in 'Radian' started by Paul Gibson, Sep 23, 2013.
  1. Paul Gibson
    Paul Gibson New Member
    Sep 20, 2013
    16
    Hello, after spending quite a bit of time on here looking for answers, is there a complete 'dummies' initial set-up guide for a Spektrum DX6i transmitter? I'm using 3 Axis Radian and having issues getting the transmitter to send any signals to the radian. There is some movements showing on the input monitor in the software, but the gimbal isn't moving at all. So, is there a guide as to the settings required within the Spektrum to get an initial set-up? thanks.
  2. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    Do you have a 3 position switch assigned as the mode switch? If the mode switch is in the off position you won't have control of the gimbal. Also make sure the check unless using Spektrum box is unchecked in the software. Each radian also had to be programmed separately, and each assigned to its position. You shouldn't have to change anything in the Spektrum transmitter itself.
  3. Paul Gibson
    Sep 20, 2013
    16
    Thanks for the reply. Correct me if I'm wrong, but the Spektrum DX6i doesn't have a three position switch?
    i shall try deselecting the Spektrum in the software, a bit odd considering that's what I'm using.
    Paul
  4. Gary Haynes
    Paul took a quick look a the online Spektrum site. If the DX6i doesn't have a three way switch you won't have a way to control the Radians modes (Off, Stabilized, Stabilized with control of Pan and tilt). And the marketing material doesn't say but on the photos I don't see any 3 way switches.
  5. Scott Stemm
    Scott Stemm Member
    Apr 10, 2013
    140
    the DX6i doesn´t have a 3 way switch it has a 2 way so off or on are the choices
  6. Matt Sharp
    Matt Sharp Member
    Apr 29, 2013
    79
    10
    You can program a mix on the dx6i to create a 3 position function on the gear channel. The programming can be a bit tricky, but you can tailor it to your needs.
    If the sliders are moving in the radian software then you are getting the correct communication. Make sure the sliders for slew are showing green. If they are red then the radians are seeing your input, but the control is disabled. You'll need to make sure your switch is assigned to enable stabilized slew.
  7. Gary Haynes
    So Hook up the receiver to a Radian and connect the Radian dongle. In the software take a look at the screen where you can see the mode position. With the Radian Mode assigned to a 2 position switch channel what do you see for values? I think you should see off and Mode 2 which is full on. Sorry I don't have access to my Radian at the moment.
  8. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    847
    67
  9. Brad Meier
    Aug 14, 2012
    749
    66
    Wow Jason, excellent find. Had no idea that was out there..
  10. Jason Smoker
    Oct 23, 2012
    847
    67
    this is very old thread I kept for good measure!! :)
  11. TROU BAYLISS
    TROU BAYLISS Member
    Mar 3, 2013
    37
    Is the DX8 any better than the DX6i ..for operating a radian / freely servo gimble
    and ..has any body had probems with a DX8 aileron pot ?? TROU
  12. TROU BAYLISS
    TROU BAYLISS Member
    Mar 3, 2013
    37
    DXI MODE SWITCH .. has a channel ..its channel 5
    DX8 MODE SWITCH .. has no channel ..you have to give it one .. the gear switch is channel 5.
    in the ..SWITCH ASSINGMENT BOX .. change GEAR>GEAR .to GEAR >INH..
    now go to FLIGHT MODE INH same box .and click on INH ..and it will change to FLIGHT MODE GEAR ..which is channel 5. which will give u stab slew .off /on .black brown green n all that good sht that makes us smile .. hope i got this right .. cheer trou
