SOP of connecting mimic beta
Discussion in 'MōVI M15' started by Button Szu, Jun 24, 2017.
Tags:
  1. Button Szu
    Button Szu New Member
    Mar 31, 2017
    10
    Respected everyone:
    I'd like to know the Standard Of Procedure for connecting mimic beta since I followed the manual step by step but it has never work out. I have to try different way of procedure to connect successfully. Sometimes, I've reverse the manual procedure to get it work.
    I've never ever to find the same way to successfully connect it, it became a serious issue for my work.
    I crave to realize the most efficiency, reliable as well as standardized procedure to successfully connect mimic beta.
    Any advise would be greatly appreciated, thank you everyone.
    #1 Button Szu, Jun 24, 2017
  2. Simon Hawkins
    Simon Hawkins New Member
    Jan 14, 2017
    Hi, check both Movi and Mimic have good power, Movi should be well balanced and on, Mimic should be 5-10 ft away and on stable terrain, i.e.- not moving. Switch on Mimic and allow a good 30secs to connect. If you have no pan and tilt then maybe the Mimic is not bound to your Movi.
  3. Button Szu
    Mar 31, 2017
    10
    Thanks Simon. Good Speed.
