Sony F55 compatible with Movi Pro
Discussion in 'MōVI Pro' started by Mitch Forst, Dec 15, 2016.
  1. Mitch Forst
    Mitch Forst New Member
    Dec 15, 2016
    Can anyone confirm that the Sony F55 would be able to be used with the Movi Pro?
    I know you can get the weight down enough if you strip it down and use a light weight lens. Just want to know if anyone has tried it, if it fits and balances?
    Thoughts?
  2. Dylan Law
    Dylan Law Member
    Nov 7, 2013
    48
    11
    Should work just fine!
    We use a F55 and M15 setup all the time.
  3. Mitch Forst
    Dec 15, 2016
    So the Pro is the same (or similar) size to the M15? I would love to get confirmation from someone who had tried with with the new Pro version before committing to buying it.
  4. Mitch Forst
    Dec 15, 2016
    Still looking for an official answer to this question. I would love to give you my money. Can anyone from Freefly confirm F55 compatibility?
  5. Dylan Law
    Dylan Law Member
    Nov 7, 2013
    48
    11
    Hey Mitch,
    I will post photos in an hour or so ..... Just let me build one up...
  6. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    They are almost same in size. If it fits to M15, it will fit to Movi Pro as well.
  7. Dylan Law
    Dylan Law Member
    Nov 7, 2013
    48
    11
    Fits just fine and tons of room to add wireless video and focus if need be
    Dan and Graham Futerfas like this.
  8. Charlie Beyer
    Charlie Beyer Member
    Nov 12, 2013
    70
    I used that same build on the M15 with a V-mount on the back which was nice for counter balance. But on the Pro, if you take the battery off and the Back plate you can use a P tap to 4 pin XLR (Right Angel) you can save the weight and power off the Movi Pro Batts.
  9. Graham Futerfas
    1,261
    245
  10. Mitch Forst
    Dec 15, 2016
    Thank you! adding to my budget to purchase this year!
  11. Dan
    Dan New Member
    Feb 8, 2015
    Hey Dylan, I had heard that the F55 could not be powered off of the Movi batteries. Can you power it using a D-Tap to 4-pin XLR cable as Charlie Beyer suggests?
  12. Dylan Law
    Dylan Law Member
    Nov 7, 2013
    48
    11
    Hey Dan,
    DTAP Out of the Power Base with XLR into the Camera works just fine. I don't have an exact run time that I could give you but since the batteries are hot swappable you could go all day.
    See you around the shop!
    Dylan
  13. Len Peterson
    Len Peterson New Member
    Jan 18, 2017
    Hey Dylan,
    Do you know if there is difference between D-Tap and P-Tap? I just don't want to fry anything if there is. I have an upcoming project with F55s and am looking to power it off the Movi Pro.
    Do you know if this cable will work?
    https://www.bhphotovideo.com/c/prod...er_POWERTAP28_PowerTap_28_28_PowerTap_to.html
    Any info is appreciated. Thanks!
  14. Graham Futerfas
    1,261
    245
    Hi Len, D-Tap and P-Tap are the same connector -- exactly the same. Some people say P-Tap (I think it stands for Power-Tap, as used by Anton Bauer), and some people say D-Tap because the connector looks like a 'D'.
    That cable should work for an F55 but it's pretty long at 28". You could shorten it if you're good at soldering, or maybe find a shorter one. You also might have to change the orientation of the right-angle XLR plug to come out of the camera the way you want.
    Here's a 20" one that's in-stock now at B&H:
    https://www.bhphotovideo.com/c/prod...er_POWERTAP20_PowerTap_20_20_PowerTap_to.html
  15. Ikbal Arafa
    Ikbal Arafa New Member
    Nov 30, 2013
    13
    Hi,
    Is there enough room to fit the Sony F55 with the axsR5 Raw recorder on the Movi M15?
  16. Boris
    Boris New Member
    Dec 23, 2016
    Other lens, 2 filter+ Metal clip-on, raw module, nothing is possible
    Brandon Obey likes this.
