Hey guys, I have read every thread on jello on this forum and I have done everything suggested with a weeks test flying / filming ! I have added 300grams of weight as well to the M5.... Is the Sony A7sII M5 Alta combination just not compatible ?? I have changed Gyro setting to 2 .. I have firmed up the stiffness ... I have run autotune and nothing works.. need help bad!
Hi Steve , I'm using the Sony 16-35mm at 16mm/ axis stabiliser off / 1/160 Sec / f12 / 4K at 100mbs. Cheers
I'd suggest using a ND filter and dropping your aperture to F5.6 or so and your shutter speed to 1/50 (assuming you're shooting 24/25 fps).
Craig, I think the 5-axis stabilisation giving a bad result on these new Sony cameras. I would suggest you to turn off 5-axis stabilisation and try again. Even you trun that functionality off, the sensor is like "floating" n its place. So any vibration, wind, wrong stiffness settings effect the A7s-II and A7r-II footage in a bad way.
What kind of jello are you talking about? I'm assuming this doesn't happen with the M5 handheld on the ground?
Hi Craig, I have very similar problem of jello effect with M5+A7SII. Did you find any acceptable settings to solve the problem? Tom
Yes. I turned it off, but someone said that in case of lenses 16-35 (it has internal anti vibration system) it's better to turned it on. I will try in few days another lens (Nikon 14-24).
I'd say start by reducing the vibes from the source...balance your props. How are you guys balancing those folding props? Yes, despite what anyone says they do need to be balanced. I bet the majority of the unstable video issues are because of frame vibration from unbalanced props.
Just been flying our M5 with the A7. We had terrible jello when using the 16-35 and none what so ever using the Batis 25 or Sony 55mm so I think it has to be the OSS. As for balancing folding blades, you need a jewlers scale that does 0.01g. Weigh each blade and then add tape at the CoG of the lighter blade. Job done. Search something like Helifreak to see how the single rotor guys balance their blades, its exactly the same.
That covered horizontal balancing, what about vertical balancing? Or is hub centering on those aluminum adapters more precise?
Because the blades are on hinges, the vertical balancing sorts itself out ie the cog of each blade will directly align itself. The only thing it cant deal with is the cog of the actual metal hub but if they are well engineered, they will be perfectly balanced anyhow.
