Shutter Release when using Futaba RX/TX for control
Discussion in 'MōVI M5' started by Cam Batten, May 31, 2015.
  1. Cam Batten
    Cam Batten Member
    Jun 10, 2013
    103
    Hey Guys,
    Is anyone operating their MoVI with the SBUS Futaba RX and have a useable shutter release? I know you can use the sbus port if you have the Spectrum rx, however I don't have that option at the moment. Any ideas?
    Cheers,
    Cam
  2. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    881
    70
    Hey Cam you can set it up through your rx/tx i have mine plugged into channel 8 which is the trainer switch what RX are you planning on using?
  3. Cam Batten
    Cam Batten Member
    Jun 10, 2013
    103
    Hey Jason,
    I've got the 8FG, and R6208 rx, from which I'm plugged into the S-BUS channel at the moment. Are you suggesting that in addition to SBUS, I can plug the shutter release into ch. 8 and then configure that as a function in the transmitter? that would be neat
  4. Jason Smoker
    Oct 23, 2012
    881
    70
    so find the switch you want on the radio, then go to the monitor on your tx to found out what channel its using then just plug it into the corresponding channel on the R6208 just like a normal servo set-up
    Cam Batten likes this.
  5. Cam Batten
    Cam Batten Member
    Jun 10, 2013
    103
    That's great. I didn't realise you could mix and max sbus / pwm. On my Jeti with PPM it's not possible. Thanks Jason.
  6. Cam Batten
    Cam Batten Member
    Jun 10, 2013
    103
    Is anyone rolling Magic Lantern RAW on 5d MKIII? I am able to trigger stills, start stop H.264 and start RAW (.raw), however I can't stop RAW rolling.
  7. Alex Shvartsev
    Alex Shvartsev New Member
    Jan 15, 2013
  8. Cam Batten
    Cam Batten Member
    Jun 10, 2013
    103
    What makes you think this works with Magic Lantern Alex?
  9. Alex Shvartsev
    Jan 15, 2013
    We are using it on our shoots with 5DM3 and ML (Movi M5 with Futaba R6208SB receiver)
    [​IMG]
  10. Cam Batten
    Cam Batten Member
    Jun 10, 2013
    103
    Good enough for me. thanks mate! What date build are you using for ML?
  11. Alex Shvartsev
    Jan 15, 2013
    np...
    these ones worked well:
    magiclantern-Nightly.2014Aug02.5D3113
    magiclantern-Nightly.2015Jan28.5D3113
    magiclantern-Nightly.2015Jun09.5D3113
