Shooting with Movi out of Helicopter
Discussion in 'MōVI M10' started by Andrew Hewson, Mar 24, 2014.
  1. Andrew Hewson
    Andrew Hewson Member
    Oct 1, 2013
    44
    Hey all :)
    Has one used a movi for shooting out of a helicopter?
    Just wondering what is the best way to do this and if anyone has any pointers? Did you just shoot straight out of the helicopter or did you use a rig of some kind.
    Suggestions would be much appreciated. Thanks
  2. Shaun Gish
    Shaun Gish New Member
    Aug 18, 2013
    I've done it several times. The basic setup we used was to rig the unit slightly inside the cockpit to a couple of bungees so that the operator didn't have to take the entire weight. We also cranked the smoothing way up to compensate for a lot of the wind gusts/course corrections. Footage looked great.
    I know that the aerial footage in Vincent Laforet's original Movi demo video was shot out of a heli... not sure what their setup was like though.
  3. Gary Haynes
    Do a search on the forum Andrew. There have been a couple of threads on shooting from a heli.
  4. Jason Hawkes
    Jason Hawkes New Member
    Jun 4, 2014
    Hi Shaun,
    Im an aerial stills photographer based in the UK, and am really interested in testing the Movi rig. Have you used other rigs before in a helicopter swell, I wondered how they compare, and do you have a link to the footage you shot online anywhere?
    Jason
  5. Be conscience of prop wash and sudden shifts in direction the Heli may make. The sudden changes in direction will increase g-force suddenly, which in turn, may cause the gimbal to go of horizon temporarily. Obviously your experience may differ because of speed, position in the Heli, etc..
  6. Sean Harris
    Sean Harris New Member
    Nov 20, 2013
    21
    Just air-to-air shot out of a Bell 407. Doors were removed. I sat in floor with feet on skids, Movi bungeed and safety wired to the passenger handle above the door (300# rated I was told...Movi rig 12# just a little overkill). Slip stream was not an issue...except for my legs on skids. At 70 Knots, better have your shoes double knotted.
  7. Daniel Holmes
    Daniel Holmes New Member
    Oct 15, 2013
    what do you mean when you say bungeed?
  8. Sean Harris
    Nov 20, 2013
    21
    Just plain ole bungee cord. I did fasten the bungee cord to locking carabiners .
  9. Even Sigstad
    Even Sigstad New Member
    Jan 2, 2014
    23
    10
    Done it a few times with good results. Removed the side door and half of the seats. Sitting inside the heli with the Movi on a Easyrig. Then leaning out as much as needed. As Chris said, when going really fast and turning the heli the horizon will go of, but it recovers pretty fast. Operator sitting in the front seat.
  10. Christer Dahl
    Christer Dahl Member
    May 14, 2015
    38
    Even, your rig has gps assist, right? How fast does it recover after a spinout?
  11. Tip Weiss
    Tip Weiss New Member
    Mar 4, 2016
    Can the movi be switched on or initialized while in motion/flying? I tried another BG and I had to initialize it in the ground before takeoff.
  12. Brett Harrison
    Brett Harrison Active Member
    Apr 7, 2013
    299
    40
    Yes, Freefly added a 'motion booting' feature very early on. There's also a set-down feature that might be useful in close quarters.
