Shaking Movi
Discussion in 'Movi Technical' started by Enes Buldur, Jul 18, 2019.
  1. Enes Buldur
    Enes Buldur New Member
    Jun 23, 2018
    Hi everyone,
    My Movi is shaking recently. I don't know why it’s did it like that. Balanced is well, no extra lens. Shot on FilmicPro, stabilization is off. Is there something I've done wrong?
  2. Kevin P Riley
    Kevin P Riley Active Member
    Jun 21, 2018
    136
    29
    Maybe try tuning it, it doesn’t look that bad for running. The up and down motion is not one of the axis that the gimbal stabilizes.
  3. Andy Johnson-Laird
    As Kevin says, Enes, the Movi cannot compensate for vertical movement -- it only stabilizes for rotational movement -- you may want to try running with a cup full of water -- if you can do that without any spilling, then you've trained your arm to dampen out the vertical motion.
    Cheers
    Rob Warren likes this.
