Setup with M10 with Epic and Bartech
Discussion in 'MōVI M10' started by Rob Seiffert, Sep 30, 2013.
  1. Rob Seiffert
    Rob Seiffert New Member
    Apr 10, 2013
    23
    Would anyone who uses their Movi with an Epic and Bartech be willing to post some pics of their rig? Still trying to get my head around how to best set this up.
    Rob Seiffert
    Madhouse
    madmadmad.com
  2. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Hi Rob, Are you using the original Bartech receiver or the PLC Fstop digital receiver?
    Best,
    Tabb
  3. Rob Seiffert
    Apr 10, 2013
    23
    Hey Tabb,
    We have the original analog Bartech receiver since we have lots of lenses without hard stops.
  4. Rob Seiffert
    Apr 10, 2013
    23
    Is the older Bartech gunna be an issue?
  5. Tabb Firchau
    Jun 28, 2012
    911
    472
    HI Rob, I need to look through old photos and see if we ever used the analog bartech, I cant recall as we mostly use the digital bartech.
    Tabb
  6. Rob Seiffert
    Apr 10, 2013
    23
    Thanks Tabb,
    In most cases, do you try to mount the focus device receiver on the camera package, or on the frame of the M10?
  7. Gary Haynes
    Rob I've seen a lot mounted to the camera and a few mounted to the mōVI tilt crossbars.
  8. Tabb Firchau
    Jun 28, 2012
    911
    472
    Hi Rob,
    I tend to mount it to the camera if space allows. The cables for the focus systems are usually stiff and thick and would reduce the stability of the system if mounted off on the frame.
    Tabb
  9. Rob Seiffert
    Apr 10, 2013
    23
    And sorry for the potentially dumb followup question, but the tilt bar is the one that the camera sits on?
  10. Gary Haynes
    Rob yes. The one photo I saw had it mounted to the tilt bar drop tubes though you could also mount to the cross tubes which actually hold the camera.
  11. Tabb Firchau
    Jun 28, 2012
    911
    472
    Hi Rob, Hugh dug up our analog bartech receiver for me. This is how we mounted it in the past. We have also mounted it on the side of the EPIC when not using the side handle.
    hope that helps!
    Tabb
  12. Lee Dashiell
    Lee Dashiell New Member
    Sep 8, 2013
    28
    11.JPG We are using the analog Bartech and have it mooted on the top rail.
      File size:
      692.4 KB
      95
  13. Arturo Bernardi
    Aug 24, 2013
    50
    Which wire connect your red-touch to the body of the camera? does the cable affect on the movi functionality?
    thanks
  14. Rob Seiffert
    Apr 10, 2013
    23
    Just wanted to say thanks to Lee, Tabb and others who weighed in with pics to help me out. We had our first shoot yesterday with the M10 and epic in dual operator mode. It was a ton of fun. We certainly found spots that we wanted to modify in how we configured things, but at least we have a useable setup. Looking forward to the various bits that are bound to pop up to make mounting, cables and power even more versatile.
    Thanks again.
    Rob
    madmadmad.com
  15. Jamie McIntyre
    Jamie McIntyre New Member
    Oct 7, 2013
    11
    Hi there,
    How is everyone powering the analogue bar tech? Using a lipo battery and a which cable?
    Also, would it be worth purchasing the rod adaptor (That fixes to the camera plate) and attaching the m-one motor there in order for a minimalist set up? I just can't see how the rods would be in the right position(way below the lens) in order to mount the m-one motor close enough to the focus barrel?
    However, the most important issue for me is powering the analogue bar tech and mounting the bar tech receiver in the best way possible? Velco, cable ties? Where!?
    I'm pretty sure the bar tech uses reverse polarity so the lipo to 2 pin lemo wouldn't work without some playing around?
