Hi all, I have looked on the Configuration manuals and not found what I desperately need to configure on the Tilt axis. It is an important part of my work on the DJI S1000 Octocopter which requires that the gimbal should be capable of setting the camera angle to face directly forward and also point down 90 degrees. This is to accomplish Photogrammetry for mapping the ground. I need to set the gimbal to do this when using one of the command levers of the controller (Spektrum not MoVI Controller). I would like this to happen as a memorised setting in the software not something that must be regularly configured in the Bluetooth settings. This is a regular necessity of my work and I would not have time to do such adjustments in the field each time I take off. Anyone out there has ever done this kind of adjustments to his MoVI and could help? Thanks for your time!
