Secraft V2 retracts landing gear for multirotor
Discussion in 'Sale / Trade' started by Nejc Slatner, Mar 29, 2016.
  1. Nejc Slatner
    Nejc Slatner New Member
    Jan 22, 2014
    26
    Used just for a test. Price of the new ones is 500$
    Price for sale: 80$
    It is designed to allow users to repair easily and All vibrations are able to adjust.
    Supplying optional parts with can be mounted on almost Multi-roters.
    Material: aluminium 6061-T6
    Total weight per one pair : 290g (1pcs 145g)
    Size : Height(48mm) Width(27mm ) Length(105mm)
    Operating Temperature: (-5¡ÆC~40¡ÆC) (23¡ÆF~122¡ÆF)
    Operating range: 90 (degree)
    Weight Test: 80kg (The SE-Retracts-Pro V2 is recommended for less than 20kg Multi rotors)
    Required:
    Bec 5V~6V 3A (Max 7.4V) (Necessarily require a power 5V~6V 3Amp) .
  2. Jason Herring
    Jason Herring Member
    Apr 7, 2013
    278
    Hi ,
    does your retracts need a controler? And do they work well?
  3. Nejc Slatner
    Jan 22, 2014
    26
    Hi, you don't need controller, you just plug into the receiver. Yes, they work well. I don't need them, because I didn't finish the project for which I bought them.
  4. Jason Herring
    Apr 7, 2013
    278
    Can you ship to Losangeles CA? And how long would it take? Where are you from?
    Thanks so much,
    J
  5. Christoph Michaelis
    Christoph Michaelis New Member
    Jan 24, 2015
    25
    Hello Nejc ... Where are You ? I'm interested ...
    Cheers, Christoph
  6. Nejc Slatner
    Jan 22, 2014
    26
    Hi Christoph,
    from Slovenia.
