second operator with taranis qx7
Discussion in 'MōVI M5' started by Semiond mathieu, Jan 22, 2020.
  1. Semiond mathieu
    Semiond mathieu New Member
    May 2, 2014
    26
    Hi guys,
    I have a movi m5 which i like always.
    Just a question, i have setup in the past with dual operator and a futaba 14sg but don't have it anymore, i have a taranis q7x, do you thinks its possible to use it with movi m5 to setup it for dual operator ?
    Can you give me some help to do this ?
    see you soon
    Hi Semiond:
    I don't really know the answer -- the Taranis QX7's web page at getfpv.com says: "Compatibility: FrSky X series, D series and V8-II series receivers (plus other receivers if an external module is used)".
    So the larger question is: does there exist an external module that will be compatible with Futaba's transmission protocols.
    I suspect you might find more people who can answer that question over on this thread at rcgroups.com.
    Hope that helps.
  3. Mark Hoffman
    Mark Hoffman Active Member
    Jul 13, 2014
    143
    25
    Many taranis rx have sbus out so yes it will work with the MoVI.
