Second LiPo Battery Mount
Discussion in 'MōVI M10' started by James Ng, Oct 7, 2013.
  1. James Ng
    James Ng New Member
    Sep 5, 2013
    11
    To keep my Movi's weight to a minimum, I've opted to power the SmallHD DP6, Teradek Bolt and Redrock microRemote (with finger focus) with a second FreeFly Lipo battery.
    I use a custom cable to connect all three devices (JST to Bolt Limo, to Redrock Limo, to SmallHD barrel connector) and at present the battery is attached wth Velcro to the top handle.
    Tabb - would you consider making (and offering for sale) a replacement top handle connecting bracket which also doubled as a LiPO battery holder. It would replace the arrowed part in my setup below? Would be great if it could include a rocker on/off power switch with a male / female JST connector. This would to allow us to turn off all accessory power without disconnecting the battery.
    For me this setup works really well as I mostly shoot with DLSRs or Canon Cinema EOS cameras which have their power so don't want to add a heavy vmount battery just for the accessories.
    Cheers
    James
    Kyler Zee likes this.
  2. Anton Ligaarden
    Anton Ligaarden New Member
    Sep 7, 2013
    How much runtime do you get with that solution? Looks really smart.
  3. James Ng
    James Ng New Member
    Sep 5, 2013
    11
    After 2 hours of continuous use, the Lipo was still putting out 15.1v - I could probably run for longer, but at that point, I generally swap over the batteries to avoid any running them too low.
  4. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Nice James, Any reason you would prefer the lipo mounted here rather then on the crossbar?
    Thanks!
    Tabb
  5. James Ng
    James Ng New Member
    Sep 5, 2013
    11
    Hi Tabb - a few reasons...
    - I've been using a LiPo battery monitor to ensure the accessories don't over drain the batteries and I find their LED's less distracting, but still noticeable back here.
    - When passing the Movi between operators it kept getting knocked when mounted to the top crossbar (I had it Velcrod to FreeFly camera mounting plate from Quadrocopter)
    - When mounted to the back of the SmallHD, the extra weight caused the LCD to more readily work loose from its ball head mount.
    - My accessories are located at both ends of the top crossbar so mounting the battery at the mid-way point made sense to me. This was the central spot the left the most clearance and gave clear access to the top handle .
    Cheers
    James
  6. Marcelo Borelli
    Marcelo Borelli New Member
    Sep 24, 2013
    James, did you make this cable yourself?
  7. James Ng
    James Ng New Member
    Sep 5, 2013
    11
    Yes it's a custom cable.
    Freefly now offer JST to D-tap or 2Pin limo cables. They can be used with off-the-shelf device power cables / splitters splitters.
  8. Joe Tamel
    Joe Tamel Member
    Oct 12, 2013
    33
    James... How do you mount the finger focus wheel to the redrock remote focus unit? Can you post pics? Thanks.
  9. Austin Glass
    Austin Glass Active Member
    Aug 1, 2013
    440
    69
    I don't know how James does it, but I just use a Collins clamp from Redrock. The CC and fingerwheel are made to go together, and it CC fits on the handle of the Movi almost elegantly.
  10. James Ng
    James Ng New Member
    Sep 5, 2013
    11
  11. Ben Huddleston
    Sep 21, 2013
    115
    21
    I have the same gear. What about the stiffness of that Lemo cable going from the base station to the FF motor? Isn't that constricting the gimbal's autonomy and compromising smoothness? If so, maybe we could make a little batch of ultra-flexible cables out of some high gauge silicone wire....
  12. Austin Glass
    Aug 1, 2013
    440
    69
    I have someone working on it. What would it be worth to have an ultra-thin Redrock motor cable?
  13. Paul McCurdy
    Paul McCurdy New Member
    Sep 28, 2013
    I'd be interested in this solution too. Both for the cables and the second battery mount on the handle.
  14. Frank-Michael Krause
    May 29, 2013
    22
    Hi you all,
    can you please tell me how to connect the lipo with the redrock? I guess i cannot simply hotwire the battery to the redrock.
    thanks for sharing
    Michael
  15. Brett Harrison
    Brett Harrison Active Member
    Apr 7, 2013
    299
    40
    Hey Frank-Michael, you can get a JST to two pin lemo adapter in the Freefly shop. I got one just in case, then got a RedRock later and was very happy with myself. True story.
  16. Frank-Michael Krause
    May 29, 2013
    22
    Yeah, should have! ..... but ordering from Germany for a single cable is %$&&%$. :)
    thx
  17. Brett Harrison
    Apr 7, 2013
    299
    40
    Oh I see, yeah well if you can source the connectors in Germany (surely) then you can get an electronics shop to wire them. Make sure you get the polarity right (it's NOT reversed).
    EDIT: I am not an electrician so check first before doing this.
    EDIT2: sorry for thread hijack.
