Scotty, I need power...!
Discussion in 'Radian' started by Joe Azzarelli, Sep 14, 2012.
  1. Joe Azzarelli
    Joe Azzarelli Active Member
    Jul 13, 2012
    210
    26
    So UPS delivered my christmas present today and I have been pouring over the Radian manual and videos. While this question may be academic for a seasoned RC guy, I am not a seasoned RC guy: How do I get power to the Radian and servos? What voltage is needed? Do I keep the MK FC board installed and pull power from it? I would think this would be shown on the wiring diagrams and/or pinout diagram. But alas...
    Thank you and I apologize for my thickness.
    Joe
  2. Matt White
    Matt White New Member
    Jul 1, 2012
    25
    I'm powering mine using a voltage regulator connected to the first channel on the pan unit, since it's not in use when you use a Spektrum satellite receiver. Otherwise your power would probably come from your radio receiver, which is how I had it powered when I tried PWM.
  3. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    I havent been able to find any real specs on voltage. Is it 5v input? Or is there a range?
  4. Matt White
    Jul 1, 2012
    25
  5. Brad Meier
    Aug 14, 2012
    749
    66
    Thanks Matt,
    My main concern is that I was running 11.1v to the FC2.1 when I had that mounted. Now that im stripping all that off Id like to still use all the batteries I have. I noticed the Radians can handle 12v. Does the software allow you to adjust voltage to the servos or should I get something like a CC BEC to regulate the 11.1v to 5v?
  6. Joe Azzarelli
    Jul 13, 2012
    210
    26
    I ended up keeping the MK FC board and pulling power from it. With the battery it helps to balance against the yaw servo, and having the buzzer attached to warn of low battery for the gimbal is a nice plus.
    Joe
  7. Matt White
    Jul 1, 2012
    25
    I don't believe the Radian acts as any kind of voltage regulator, so if you put in 12V it's going to pass that along to the servos, which you probably don't want. I'm using as SBEC between a 2S Lipo and the Radian to step it down from 8.4V to 6V, which seems to work fine.
  8. Andy Johnson-Laird
    Based on what I was told by Jeff and others, the way to go is to use a 3S Lipo feeding into a BEC capable of delivering 5A (actually, I may have been told 10A in case a servo stalls) at 5v. Feed that to the receiver, then the servos get their power from the receiver. Use a second Recom/Arch 5V at 1 amp DC/DC converter to provide clean +5 to a Strato Snapper or MK IR Control. Both the BEC and the Recom have a common ground. Make sure that the receiver to Strato Snapper or MK IR Trigger servo connectors do not feed noisy power SS/MK IR.
    I discovered (the hard way -- what other way is there? See thread at http://forum.freeflysystems.com/ind...rigger-goes-catatonic-in-flight.109/#post-927), that the servos put a lot of noise back on the +5v supply line -- I presume this is back EMF and the servos don't appear have snubber diodes to prevent it. I was measuring (using a scope) as much as +4 to -2v spikes on the +5v supply line -- so much so that I burned out a Strato Snapper and the MK IR trigger didn't work reliably. The moment I added the Recom 5v for the Strato Snapper and MK IR trigger, both were rock solid -- I use only one of them not both simultaneously.
    The FC has two 78S5 Recom DC/DC converters. One it uses for +5 for the FC board itself and the other to drive the servo. Each is only capable of 5V at 1 Amp which, based on what I learned, is not enough for the three FFF servos. As I recall each servo can pull 1.5A in normal operation, more if the motion is obstructed and the servo stalls.
    I believe it's also a good strategy to use the Radian "mode control" on all servos so you can de-energize all the servos in case you need to. Like if you happened to land in a tree. Ask me how I know. :( (Summary: I failed to notice a Radian beta tilt sensor's double sided tape had almost come off when I mounted the 5DM3. Sensor then does come off in flight and flaps in the breeze. Camera counterflaps in response. Got the C8 back from out over the river/ravine but did not have control authority (or piloting skills or both) to prevent tree landing. Considering hard crushed concrete ground of dam demolition site, a tree landing turned out to be the luckiest thing to have happened. Lost some props, but no carbon fiber broke. Underwear replaced. ;) )
    Hope this helps
    Andy "head for the woods."
  9. Josh Lambeth
    1,315
    216
    That sounds scary!!! Do you have that video?
    I was also using the old FC to power my system. I then switched to a 10A castle BEC and things seem to be a much quicker response then it was on the FC.
    Josh
  10. Andy Johnson-Laird
    The client has the video. Probably just as well, as I'm not sure I need to relive it! :) I'll ask if I can get a copy and post it.
    I would imagine the extra current available from the BEC would make the servos much more responsive.
  11. Jim Swanson
    Jim Swanson Member
    Jul 13, 2012
    97
    Hey All,
    I'm running a Freefly HDMI converter with a Castle BEC and a 3s lipo. Down conversion is 5v.
    Can I "Y" off this BEC to run the 2 Radians and Savox servos?
    I'm thinking this might save the weight of more batteries ....if possible.
    Thanks,
    Jim
  12. Wing Gee
    Wing Gee New Member
    Aug 1, 2012
    15
    I'm currently running 3s into a "Sport BEC" from dimension Engineering. It's only capable of 3A, but so far, it's operating fine at 6v. I'll need to put a heavier load on the gimbal and measure the current, to make sure i'm not overloading the BEC. I have a hobbywing 8A BEC, but its fairly bulky. I'll switch to it if I have to.
  13. Andy Johnson-Laird
    The short answer is yes, Jim.
    The longer answer (as we say in the software business) is, yes, that should work. ;)
    If you see any video artifacts caused by electronic noise from the servos on the +5 supply, then you will need to add an independent Recom/Arch +5v DC/DC connected directly to the 3S Lipo and sharing a common "ground" (negative terminal).
    Ady.
  14. MIke Magee
    MIke Magee Active Member
    422
    103
    I'll be programming the radians this afternoon. It's clear that the first pass should be made not attached to the servos. However (since this is a "power" thread) can/should the radians be daisy-chained to take the power from the pan to the roll to the tilt and each programmed in turn while daisy-chained?
  15. Andy Johnson-Laird
    I added the Radian sensors one at a time to the "daisy chain." Pan first, roll, then tilt. Why? It just seemed more rational to do it that way so that if there was a rogue sensor, I'd be able to find it straight away. I guess I was following a basic diagnostic rule: only change one thing at a time. ;)
  16. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Yes that is correct Mike, the male to male extensions included in the kit will bring SIGNAL / POWER / GROUND from one module to the next.
  17. Alexander Jenal
    Alexander Jenal New Member
    Sep 20, 2012
    So, just to get it right... When I use the S.Bus wiring (page 10 of instruction manual), the only way to get power into the system is the red and the black cable of the S.Bus. Right?!
  18. John Cunningham
    Jul 5, 2012
    183
    13
    Alexander,
    The Radian will accept power on the lower 2 pins of any port - just like a normal receiver. Normally you would plug the power into your receiver then the SBUS output would take this power to the radian modules.
  19. kjetil tønnesen
    Aug 16, 2012
    417
    23
    hello
    i have the 3x gimble ,but i dont have radian on pan,just tilt and roll
    so how does i connect the pan servo so i can pan with my second mx 20 graupner radio
    thanks
  20. Tabb Firchau
    Jun 28, 2012
    911
    472
    You can just connect the pan servo to any of your RX ports that you want to control pan with.
    Tabb
