What are safe RSSI levels for the RFD900? I see in the user guide under troubleshooting it says: "The current reading displayed on the Horus is not accurate, we are currently working on a fix for this issue." Does mean that RSSI on the Horus is not usable? Can I use the RSSI in QGC reliably instead?
I am using Futaba 14sg and the range is so bad. I couldn't even see the RSSI for telemetey, only the RC signal. I did not see it on the QGC either. I have asked Freefly about this and they said i dont relly need this reading because it is unreliable. I got mine in August 2023. Is freefly going to fix this issue anytime soon? Need the RSSI indicator so i could adjust my mission range.
