hey all i have a problem where myRoll is suddenly not center. last night the switched on the movi after take-off and the movi now thinks the its 15degrees is 0 start. Even if i adjust it back to zero it still a least another 5 degrees off? i tried downloading new software, tuning adjusting movi is well balanced, autotune even tried upside start nope nada any ideas
Hi Jason...that's very odd. You may have to open up a ticket by sending an email to Freefly Support (support@freeflysystems.com) I'm afraid... Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
Yeah andy 5-6yrs no problems then suddenly this happens while on the job super strange, already contacted freefly
Any chance a cable's come loose? Might be worth checking and re-seating as I know you're in Nihon and it's going to be tough to send it back to FF.... Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
Andy, I figured it out, somehow the roll and tilt where on the same channel, I was watching the tilt slowly and then i thought if i moved the camera fully down the roll become level! Haha some how it got changed glad its fixed!
Nice forensic work, Jason. Not sure how you managed to configure them on the same channel -- not that *I* have ever done anything like that, you understand.... Cheers Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
