roll remote seeting problem
Discussion in 'MōVI M10' started by Brice Tholozan, Feb 26, 2016.
  1. Brice Tholozan
    Brice Tholozan New Member
    Sep 6, 2013
    29
    Hi,
    When I'm push the stick of my controller (Futaba T14SG) to set the roll it works, but when I let the stick go back to the center (in it's native position) the roll of the MOVI go back too.
    I would like to know how can I set the roll in a position and leave it that way when I'm letting go the stick to the center ?
    Here is a video to show you the problem :
    Thank you for your answer
  2. Graham Futerfas
    1,258
    243
    Can you use the Roll Trim adjustment to set it? On the Spektrum, you can use the little left-right toggle underneath the Roll stick to hold it one way or another, or you can set it in the app.
    Unfortunately, these adjustments may not Roll it enough for you, since they're more minor corrections.
  3. Brice Tholozan
    Sep 6, 2013
    29
    ok thanks you for that
