Hallo together, I have a big problem with my m5 on a Octocopter. I'm using the latest firmware 3.08. I use a 5D Mark III with 24-105 lens without an image stabilizer. Whenever I fly with the copter to the left or to the right, tilts the roll axis of the gimbal. The picture is wrong. The camera always looks to the front at this flight. I've already tried everything I can resolve this error not. Someone has a tip?
Sebastian are you in Handheld or Aerial Mode? Are you using the remote? If using the remote what position do you have the Kill/Majestic/Dual switch in? Likely you have the M5 in Handheld Mode rather than Aerial Mode.
Good Morning Gary, we fly in majestic mode. Not in Air boarn. But we have tested in air boarn too. The same problem.
It was me, flying with Sebastian yesterday. We really tried everything. Airborne and Hendheld, setting the Rollstrength up to 40, rebalancing, retuning, majestic angle and ??-mode. We tried with the roll control switched on and off at the Remotecontroller... After doing some moves in the air the Roll came off slowly to about 15 degrees and rebalanced very sloooooowly while doing some paning. Any suggestions? Thanks Norbert
Sebastian please save your config file and then attach it to a reply. Also photos and videos might help us determine what is happening with your setup.
Sebastian your stiffness settings appear to be low. Did you use the Auto-tune or manual tuning? Also as Tuuuka asked is your balancing spot on? Also your Hold Strength for all channels is at an 8 setting. Is that something you changed? I think the default is 3. Might try changing that back.
Hallo Ylonen, yes the balance is perfect. Hallo Gary, yes we have tested with auto-tune and manual too. And the roll we have maked a test with 28 and 38 in the settings but no change.
Hallo Gary, i have sent an email to the support. Insert a video of the problem yesterday we have and the settings. Thank you and i hope the best.
