Hey does anyone have an issue when tilting down the roll (and sometimes the pan axis) starts to drift? Looking forward, horizon is fine. However, as I tilt down the roll starts drifting camera-clockwise to about 10-15 degrees or so by the time I'm looking straight down. The battery voltage was 16.31V so it wasn't because of a low battery, I think the balance is pretty good - any ideas?
Check the balance with the camera in that tilt position. Check all three axis. Try it with someone holding it as if operating rather than in the stand so that you can get the settings as high as possible.
Thanks for the response. The balance was good - I reset the whole system to defaults and reset the controller as well and it seemed to fix the problem the next morning. It's weird because I did this for this video with no luck.
