Roll balance
Discussion in 'MōVI Pro' started by Ulrich Thomsen, Feb 25, 2017.
  1. Ulrich Thomsen
    Ulrich Thomsen New Member
    Apr 22, 2015
    17
    Hi,
    Why does my roll balance keep centring itself?
    overall the system is balanced, but when I roll the gimbal to its other positions, it's supposed to stay like that, but instead it rolls back and centres itself. it's the same in both directions. The camera package it not heavy to one side. It's perfect in balance -- when it's centred.
    What am I missing here?
  2. Graham Futerfas
    1,261
    245
    Hi Ulrich, I've noticed this too, but haven't put a lot of thought into it. Maybe it has to do with the 'Roper-Flipper' cable that connects the GCU to the TSU. That could be putting some tension on the Roll Axis and causing it to return to a neutral position. I could be wrong.
  3. Chris Fox
    Chris Fox Active Member
    Apr 14, 2013
    463
    86
    Hi Ulrich,
    This more than likely means you vertical balance in the tilt stage is too low. Hence the camera will always hang back in the centre position. As you raise the camera you will find the tendency changes for the camera to always fall away from the centre position when the vertical adjustment is too high.
    Depending on the length of the lens you are using tilt the lens vertically and then adjust the tilt cage position within the frame.
    Hope that helps.
  4. Ulrich Thomsen
    Apr 22, 2015
    17
    The tilt balance "front to back" is perfect in balance. Also the vertical axis tilt balance.
  5. Chris Fox
    Apr 14, 2013
    463
    86
    have you got any cables running from the camera to the ring or handle bar?
    There is an inter relationship between the vertical height of the camera in the tilt stage and the roll balance.
  6. Ulrich Thomsen
    Apr 22, 2015
    17
    Only default cables...
    What's that inter relationship about ? What can I do different then ? If I change both the tilt balances, they go out of balance
    #6 Ulrich Thomsen, Feb 26, 2017
  7. Chris Fox
    Apr 14, 2013
    463
    86
    If the camera is too high in the cage, then the tilt balance and roll balance is going to be statically unstable (wanting to roll away from the centre all the time) If the camera is too low then it then you will be able to balance the camera forward and backwards in the tilt stage (as it hangs in position) and you will be able to get it to balance in roll, but again it will be hanging in position.
    The problem with the camera hanging in position is that it will appear balanced, but when you start throwing the gimbal around, you will lose your horizon.
    When the camera is raised up and you achieve the balance where you can put the camera in any position and it stays there, then you are on the money.
    Here is Tabb explaining it
    Hope that helps .....
  8. Ulrich Thomsen
    Apr 22, 2015
    17
    Hi Chris,
    I understand this. That's what I said previously; all the tilt balances are in perfect balance -- "front to back" and the vertical tilt axis (using the terms of the manual)
    #8 Ulrich Thomsen, Feb 27, 2017
  9. Chris Fox
    Apr 14, 2013
    463
    86
    Hi Ulrich,
    What does the balance display on the MoVI Pro screen say, are all the lines in the centre for tilt, roll and pan?
  10. Ulrich Thomsen
    Apr 22, 2015
    17
    they "dance" a little around the center. I also hear some motor working, as if I need to manually lover the setting. Even when pick it up.
    #10 Ulrich Thomsen, Feb 27, 2017
