Hey Guys, last december i bought the M5. Indoors everything works perfectly (while indoors I was not connected to GPS) and I am very very happy with it. But as soon as i get outside i have to following problem: When I pan the Movi to do a 90° turn or even more the camera is tilting and rolling and don't holding the position. (tilt is locked and I was in Majestic Pan). This isn't just 1° or so its way more, I would say around 10-15° even more sometimes. If I restart the Movi it seems to work but only for around 1-3 minutes, then its going to drift away again. I was connected to around 7 satellites via GPS. First I was thinking that it has something to do with low temperatures (system-temperature displayed in the Android App was around 20°C, temperature outside was around 7-10°C), but i even tried it on warmer days with the sun shining: same Problem. Some other parameters: Roll Stiffness:35 Shaky-cam Pan:0 Shaky-cam Tilt:0 Pan Smoothing:28 Pan Stiffness:53 Tilt Smoothing:15 Tilt Stiffness:26 Nikon D600 with 14-24 at 14mm, so not too heavy at all. I am sorry if it's just a small problem and I am basically to dump to use it right or this question is answered already. Cheers and Thanks! Robert
